Dialogbox problem
Hello all,
when I use @DialogBox, how I can check user choose “ok” or “cancel” ?
Could you please give me the code in formula ?
Thanks in advance
Sonja
Subject: Dialogbox problem
Result := @Dialogbox( etc…If the user selected Cancel, result is empty.
Result := @DialogBox( “nSubPopup_Report_Select”; [AutoHorzFit] : [AutoVertFit] : [OkCancelAtBottom] ; “Title” );
@Prompt( [Ok]; “Result”; @Text( Result ));
Subject: RE: Dialogbox problem
Thanks Herbert!
Sonja
