hi all…
kindly help me. i use dblookup to get all the value from database and prompt the list, and it working, but how can i add new choice in dialog box that give user to fill up the course name rather than take from database… The keyword for user to choose if they want to fill in is -OTHERS-
Sub Click(Source As Button)
On Error Goto ErrHandlr
Dim uidoc As NotesUIDocument
Dim doc As NotesDocument
Dim db As NotesDatabase
Dim tserver As String
Dim dbfilename As String
Dim lkpView As NotesView
Dim sessionDoc As NotesDocument
Set doc = uidoc.Document
If uidoc.EditMode Then
sReturnvalue = getdbserverpath(db,"Training Records Management") 'lookup server and db
tserver = Strleft(sReturnvalue,"~") 'lookup server and db
dbfilename = Replace(Strright(sReturnvalue,"~"), "\", "/") 'lookup server and db
Set svrName = session.CreateName(tserver)
cnLookup=DbColumn(tserver, dbfilename, "lsvCourseSession", 0)
cnPrompt = ws.Prompt(PROMPT_OKCANCELLIST, "Course Name", "Select course name...", " " , Arrayunique(cnLookup))
key = cnPrompt
Set lkpView = db.GetView("lsvCourseSession")
Set sessionDoc = lkpView.GetDocumentByKey(key, True)
'If (cnLookup="-Others-") Then
' cnPrompt = ws.Prompt(PROMPT_OkCancelEdit, "Course Name", "Please enter new course name", " ")
'End If
' to check sessiondoc exist
If Not (sessionDoc Is Nothing) Then
doc.CourseName = cnPrompt
doc.TypeOfTraining = sessionDoc.TypeOfTraining
doc.AppCat = sessionDoc.AppCat
doc.Objectives=sessionDoc.Objectives
doc.CourseLocation = sessionDoc.CourseLocation
doc.Facilitator=sessionDoc.Facilitator
doc.StartDate =sessionDoc.StartDate
doc.EndDate= sessionDoc.EndDate
doc.Duration = sessionDoc.Duration
doc.Act_CF = sessionDoc.Act_CF
doc.Refreshment = sessionDoc.Refreshment
doc.nFees= sessionDoc.nFees
doc.TotalCFees= sessionDoc.TotalCFees
doc.Payment= sessionDoc.Payment
doc.Payable = sessionDoc.Payable
Call uidoc.Refresh
Else
'Messagebox "The record for course profile cannot be found" & cnPrompt & " is not available. Kindly contact the respective person to create new. ", "Information"
'MessageBox message [ , [ buttons + icon + default + mode ] [ , boxTitle ] ]
Messagebox "The record for the course profile cannot be found" ,MB_OK + MB_ICONINFORMATION, "Information"
Exit Sub
Exit Sub
ErrHandlr :
If Err = 4411 Then Exit Sub
Msgbox "ERROR : " & Err & " - " & Error & " at line " & Cstr(Erl),16,"Select Course Name Button"
Continue = False
Exit Sub
