From Designer Help database:
Example
Returns an identifier for a font face in a document.
Note This method is new with Release 6.
Defined in
NotesRichTextItem
Syntax
notesFont% = notesRichTextItem.GetFormattedText( faceName$, addOnFail )
<---- Should read: notesFont% = notesRichTextItem.GetNotesFont( faceName$, addOnFail )
Parameters
faceName$
String. The name of the font face, which must be valid for the platform on which the agent is running.
addOnFail
Boolean.
True assigns an identifier for the font face if one is not already assigned in the current document.
False (default) returns 0 if an identifier is not assigned for the font face in the current document.
Return value
notesFont%
Integer. The identifier associated with the specified font face, or 0.
Usage
The identifier can be used to set NotesFont in NotesRichTextStyle.
Identifiers assigned by GetNotesFont are in the range 5 through 254.
Language cross-reference
@FontList function in formula language
Example
See Also
Working with text in LotusScript classes
