Designer 8.5 Help is "-less"
OK - who is responsible for the 8.5 Designer help database ? What use to take seconds to look up Note classes / methods is now taking “many++” minutes. Is there a way to remove the federation of all the installed products from help ? That would be a start.
How about allowing us to just use a fast lookup view so we can quickly enter the beginning of a Notes class.
No offense, but I was almost anticipating that MS Office help was installed.
I do , however, like some of the extra DDE customization features.
Subject: Same here but there are missing elements too
How about some documentation on the XPages elements? There is nothing to describe the properties of anything you drag onto the design surface (anything that in source code looks like xsp:control.
It would also be nice to see some documentation that talks about the document life cycle and how all the part relate to each other. I think I finally get it but it took a while.
Subject: I can only agree
I went back to open the help database from the client
