Hi, I have got a problem with my Domino Designer 8.5.1. It does not work with Windows 7. Your ar not available for open apps, it leaves you waiting for…
Any idea?
Thanks beforehands.
Any idea?
Thanks beforehands.
Subject: same problem here
Win7 x64 -When ever I load the designer client… the darn eclipse crap appears to hang the designer until it “decides” that it has refreshed that blank DB you just created yesterday. (amongst other tasks (whatever they are))
Eclipse also slows the windows UI once the designer is open. Close it and you get some sembelance of performance back.
Subject: No known problem with W-7
Hi,There is no problem with regard to windows7, i run the designer 851 in windows 7 fine.
Just check your memory & no. of other apps you use simultaneously. It must be more than 1 GB for a smoother operation.
Subject: So sorry but…
I´ve got 3 Designers running on W7 and any of them does not work fine.
Thanks beforehands.
Subject: R 8.5.2 designer works on my laptop Windows 7 Enterpris Version 6.1 (Build 7600)
BR
Mov V. Hansen
Subject: Install the latest fixpack.
8.5.1 is only certified on Windows7 since fixpack 1.
Fixpack 4 is out, so install that and see if the issue persists.
Subject: Worked fine until FP3 for me but not with FP4 on XP
I am running into the same problems as the OP. No problems on XP (haven’t tested W7) until FP3. But with FP4 Designer is not usable.
Subject: Domino Designer 8.5.1 FP2
I have installed FP2 today but it persists. I will try with FP4.
Subject: Did you check your connections?
Works like a charm on my laptop (W7Pro/64bit, N8.5.1FP4)
Did you check connections, ports, location, etc. to be all set up correctly? Had some troubles with that on my initial install…
Subject: It worked so fine…
since the begining but a few days ago all my installations left to work. I wonder it could be a windows update case.
Any Idea???
Subject: Works like a charm on my laptop (W7Pro/32bit, N8.5.1FP3)
