Hi All,
I have a user who gets the following errors a bunch of times when opening/closing e-mail memos…
Error loading USE or USELSX module: CoreEmailClasses
Duplicate Public name CMEMOOBJECT in USE module CoreEmailClasses
error processing use list module: (Globals) FollowUpMemosubform
This happenes on both server/local replicas. I have replaced the design on both mail files - no good. I’ve ran fixup, updall, compact - no good. Strange, I open user’s server mail on my client and I don’t get the errors. We both have same version. Could it be the ECL?
I really don’t want to replace code in the script libs as some posts suggests because this is a users production mail file. Is there anything else I can try??
Xie Xie
Subject: design replace dosen’t fix errors … Error loading USE or USELSX module
Try deleting the cache.ndk. If that doesn’t work, then try renaming bookmarks.nsf to bookmarks.old and restart the client. If neither of those work, then have a look at the ini file. You may need to delete everything except for the first 3 lines and re-build the client.
you could try opening their mail file in designer and picking Tools > Recompile all LotusScriptit tends to correct these errors as theyre usually code based.
alternatively, when you refresh the design, check what elements it refreshed and run the refresh again (you can do it three times if there are a lot of changes the first time around), if it refreshes the same stuff then it’s corrupt and you have to delete it first and then do the refresh to put it back, that usually fixes the problem as well.
don’t ever be afraid of deleting design elements from a mail file (except the private ones) as the design task will always put them back in again.
Subject: RE: design replace dosen’t fix errors … Error loading USE or USELSX module
If refresh/replace design doesn’t work and deleting the cache.ndk, etc also doesn’t work, you can try creating a new replica. I have found that this sometimes will fix such problems.
This problem occurred for us when we upgraded from Notes 4.6.7 to 6.5.1. The problem was resolved by upgrading the folder design of the mailfile. If you have a local replica, do it on the replica first to see if it corrects the problem
In your Inbox, select
Actions > Upgrade Folder Design > Manual Upgrade > Select All (Inbox) > Ok
We chose Manual Upgrade over Automatic as it gives you a little more control over which folders you want to work on.
Other than that, it worked sweet!
Try to downgrade the design to an earlier version and upgrade it again (backup)
