Design problem - text partly outside fields
I have a problem to understand and solve some design difficulties.
I have a form with some tables. The first cell in a table contains plain text which is OK.
The next cell in the same row contains a field with the following properties:
Type = Editable text
Style = Native OS style
Width = Fixed 4.000 cm
Height = Fixed 0.635 cm
The table has the following properties:
Table width = Fit to window
Cell width = 7.340 cm
Cell border style = Groove
Cell border thickness = 3 (all sides)
Background color is set
Left table margin = 2.499 cm (absolute)
Right table margin = 100 Relative %
All my form has these properties in a total of 8 tables. The tables are placed inside sections.
When the form is presented on screen all text are inside the fields (also the native OS fields)
When I printout all the Notes fields are OK but the text in the native OS fields are starting with half of the first letter/number outside the field.
I want to use the native fields so how can I correct this from happening ?
