Design help
ok dumb question sorry to bug you. I have a field in a form and I want to grab the data from another database and have it populated. Example We have a customer NAB with all their if in it. and in my form I have a customer field where the user choose’s the customer they want now I have a phone number field and I would like it to auto populate from the customer nab when they choose that customer? Any idea how to code this with functions? I know it can be done as I have example code from another database but can’t get it to work. Here is the example code I have.
vServer :=@Subset(@DbName;1);
vCompany :=Cont_Company;
REM {@Prompt([OK]; vKey; vserver)};
list :=@DbLookup(“”;vServer:“NAB”;“(ZCompanies)”;vCompany;2);
@If((@IsError(list) | list = “”); “Phone# Not Found”; list)
Subject: design help
Here’s what your code is doing:
  1. vServer :=@Subset(@DbName;1);
Gets the name of the current server. Is OK.
  1. vCompany :=Cont_Company;
Gets the contents of the Cont_Company field. Is cool if that’s the actual name of the field you want to get data out of.
  1. REM {@Prompt([OK]; vKey; vserver)};
Commented out, so nothing happens. Fine.
  1. list :=@DbLookup(“”;vServer:“NAB”;“(ZCompanies)”;vCompany;2);
Here’s where it may get tricky. What’s happening here is that it’s looking at a database with the file name NAB on the server which you got the name of in line one, locates the (ZCompanies) view within that, looks for the line in the view where the value in the first sorted column is equal to whatever the value of the variable vCompany is, and returns the value from the second column in that row.
So what could be going wrong here? First guess is that you’ve got the file name wrong. The title may be NAB, but if the filename is nab.nsf, you want nab.nsf in that spot. Also check to make sure that the (Zcompanies) view exists and that the first sorted column (visible or not) contains the company name that you want to look up against.
  1. @If((@IsError(list) | list = “”); “Phone# Not Found”; list)
I like to use the [Failsilent] directive in @DBLookup (look it up in the help). If you use that, you can remove the @IsError bit from this line.
Subject: RE: design help
Thank you a ton for the explanation of what the code is doing. After I read that and had another person look at the code I found my error. I didn’t have the Customer_NAme field auto refresh so the data wasn’t being loaded for the phone number field. Changed that and it now works. Thanks again for the help
