Default switches for Fixup, Updall, Compact console command?
If I issue a maintenance command at the console, what switch is being used? What is the default?
*** l updall “database” does WHAT?
-V Update: All built views
-F Update: Full text indexes
-X Rebuild: Full-text indexes only
-R Rebuild: All used views
-A Update database configurations: Incremental
-B Update database configurations: Full
*** l fixup “database” does WHAT?
-I Scan only since last fixup
-F Scan all documents
-Q Perform quick fixup
-V Exclude views
-N Don’t purge corrupted documents
-U Optimize user unread lists
-J Fixup transaction-logged databases
-O Fixup open databases
-Z Don’t fixup open databases
-C Verify only
-Y Fixup subdirectories
-y Don’t fixup subdirectories
*** l compact “database” does WHAT?
-D Discard any built view indexes
-R Keep or revert database to previous format
-b In-place
-B In-place with file size reduction
-c Copy-style
-L Copy-style: Allow access while compacting
-i Copy-style: Ignore errors and proceed
-f Document table bitmap optimization: Off
-F Document table bitmap optimization: On
-h Don’t support specialized response hierarchy: Off
-H Don’t support specialized response hierarchy: On
-t Enable transaction logging: Off
-T Enable transaction logging: On
-u Don’t maintain unread marks: Off
-U Don’t maintain unread marks: On
Thanks,
Brian
Subject: Default switches for Fixup, Updall, Compact console command?
Updall (I assume that’s what you mean instead of Update) is -F and -X by default.
Fixup is -I if run on multiple databases and -F if run on a single database.
Compact is -B if you are not using transaction logging and -b if you are.
Subject: RE: Default switches for Fixup, Updall, Compact console command?
Thanks…I looked and couldn’t find the answer.
Brian
