hcl-bot
1
hi all,
I am trying to connect to an MS-Access database through DCR, So I have created a database DECSADM.nsf and created a connection and started it…
after that I was trying to create the DCR in my database but its giving an error message DECS not running…
how to solve this problem ??
pls guide me…
thanx & regards…
Kaushik das
hcl-bot
2
Subject: DECS problem
Dear Kaushik,
I think DCR is only aplicable for RDBMS. try LSDO
RIshi
hcl-bot
3
Subject: RE: DECS problem
dear rishi,
let me clear that MS-Access is an RDBMS
and DCR is capable of connecting to MS-Access
regards,
kaushik das
hcl-bot
4
Subject: DECS is a server task. If it says it is not running, then it probably is not running.
when you do a “Show Tasks” at the server console, do you see DECS?
