DECS - DB2 Connection Problem
Hello,
I have been facing a problem while trying to connect a DB2 UDB version 9.0 installed on a NT machine.
I have been trying to connect the DB2 database using DECS. From Domino server I tried to create a connection. I have entered the DB2 Database name username, password. (Please note I am not using ODBC.)
Now as soon as I clicked on Owner/Name button in Table Selection Section it shows the following error:
[Error]:[IBM][CLIDriver][DB2/NT] SQL0443N Routine “SYSIBM.SQLTABLES” (specific name “Tables”) has returned an error SQLSTATE with diagonistic text “SYSIBM:CLI::-805”. SQLSTATE=38553, Connector ‘db2’, Method - Catalog[Metadata]-(-443)
Could it be any security problem (I have been using administrator username and password for both Domino & DB2 and DB2 client has been installed in the Domino server node and same username/password works fine from DB2 client itself)
I am not sure what could have gone wrong.
Could anyone provide any suggestion/solution to this.
Thanks in Advance.
Sudip
Subject: DECS - DB2 Connection Problem
It could be an issue with access rights. Refer:
http://www.thescripts.com/forum/thread521541.html
Regards
Litty Joseph
