Debugger problem
In a partical database, when debugging the debugger keeps coming with a previous event, e.g. when i have a script in database open this event gets called in the debugger when opening a form or starting an action on that form. When I remove the script in the database open some other latest event, e.g. when i first open my mail, close the document the document close in the memoform is displayed. My only option is to close the debugger. it seems not to appear in other databases.
UPDATE
Solved by creating a new template and copying all the elements to it. Strange, but it works
Anyone??
Applying fp2 did not solve this.
Regards
Walter Mobach
