@dblookup: Problem in Column and not in a form button
Hi All,
I have a problem in the following formula language.
@DbLookup(“”:“”; “CN=ABC/O=ORG”:“Check\Hello\Test.nsf”; “vwName”; “KeyName”; 3)
When i put the same code in the button with a prompt for the output, it works fine.
But when the same formula is used in a view in one column, no values are displayed.
I have tried to check for the Error using @iserror but no error.
This is driving me crazy… Please Help.
Regards,
Priti.
Subject: @dblookup: Problem in Column and not in a form button
Read the documentation for @DBLookup again. You can’t use it in a view.
Subject: RE: @dblookup: Problem in Column and not in a form button
Opps… Stupid of me… :slight_smile: Thanks for ur post.
