There seems to be a bug in the Outlines in Notes 6 when outline entries are copied between outlines in different databases.
When I set the outline entry to link to a named element (views), and set the database to - Current database - in an outline entry everything works ok. But then when I copy these outline entries to another database, the - Current database - setting in the outline entry has changed to the database where the entries were originally created.
Since i am using the COM classes to synchronize outlines between databases this is a big problem for me since the outlines are then always pointing to a database template of the master database, and someone has to go in and set the database target for each outline entry.
I tried to copy the entries manually and the linked database name is still changed so it is not only a problem when using the back end classes.
I guess it works switching the outline entry from named element link to a formula action, but then i do not get the neat selection focus on the outline.
btw. Doing this in Notes 5 seems to keep the correct database target when copying across databases.
regards,
arni
