DAOS problem: Save failed, Document attachement is invalid or Document attachement is invalid: Could not save to file C:\users
I recelntly upgrade a domino v11FP1 server.
I configure transactional logging and DAOS.
When I test Daos with one database, NLO files are created correctly on the specified disk, Catalog is synced, No NLO are missing, BUT:
From Notes Client, when trying to save the file/attachment on the desktop, I get error message: Save failed, Document attachement is invalid From notes client,
When trying to open the file: Error message: Document attachement is invalid: Could not save to file C:\users.........
DAOS is brand new. Any clue ?
Hi Dominique,
Two of the reported similar issue were resolved by following below steps. It seem issue with daos catalog.
Please try the following.
1) Issue the below commands on the server.
Tell DAOSMgr Resync
Tell DAOSMgr Resync -quick
Tell DAOSMgr Resync -force
Test the issue.
2) If the above command didn't solve the issue then restarting the Domino server may resolve.
Thank You.
Regards
Shrikant J
I have done 1/ and 2/ to solve the problem.
It solved the case !!
Thank you.
