Hi, I have installed DAMO 8.0.2 Fix Patch 4 on Outlook 2007 with Windows XP SP2 and I’m having problems synchronisation. Any emails that appear in the inbox (via Notes Client) do not appear in Outlook? I can send emails without any problems from Outlook but cannot receive any emails.
If I re-install the software everything works fine for a while until the PC is rebooted and then I can no longer receive any emails agin but can send.
I have added the following into the NOTES.INI file, but still have the same problem.
REPL_PST_DEBUG=1
CONSOLE_LOG_ENABLED=1
I have also opened the nsf file located in the DominoForOutlook folder and the emails do not appear in the database. I have deleted replication history and then attempted to launch Outlook but this also failed to fix the problem.
Any help would be gratefully appreciated.
