- This appears to have been that View. I tried other Views, both categorized and not, and they all work. Don’t know why DDE thinks it’s okay and it breaks, but there it is.
Subject: forwarded to runtime team
can you paste in the source of the page or send a sample db?
Subject: Not seeing this, what’s your scenario?
Hi Dave,I’m not seeing this when I tried the discussion app. So we may be missing something, what is your scenario?
regards,
Paul.
Subject: Sorry to bother you, Paul…
Apparently the edits didn’t replicate, or do it before you saw. This was a problem with the View that I was using, not the ViewPanel. I discovered any other View worked fine, so I created a new View specifically for the XPage and it’s working beautifully.
Most likely unless you have a View that is “corrupted” just like mine (works in Notes, doesn’t in XPages) it will be essentially impossible to ascertain why DDE didn’t complain when using the “corrupted” View. Since a new View fixed it, it’s a non-issue as far as I’m concerned.
I was hoping my edits to remove everything and the “Solved” marker would prevent anyone from spending time on it.
Thanks for your time…
