I am running into a problem where every time an email comes in, the window I’m developing in loses cursor focus, and I lose part of what I typed, or, worse, the copy-paste operation I ended up performing mid-focus-switch occurs elsewhere than intended. I am on Notes Designer 9.0.1 FP2. Is anyone else running into this problem?
Subject: Mail preferences
Check your mail preferences and see if you are set to automatically notify you when new mail is received. Turn that off and see if it helps.
