Crystal Report Print Engine API in Domino
Hi, I would like to print crystal report using Print Engine API. As refer to some of the discussion in Notes/Domino 4 & 5 , global.nsf & global32.lss are the example that requested to refere to, but I found that these 2 example are from older version of crystal report and Notes.
The object that used in the Lotus Script is not supported in Notes 6, so I would like to know whether there is any references from the latest version of crystal report and notes or any other method that allow me to achieve my goal?
