Crystal Enterprise 10 Installation Problems
I just bought Crystal Enterprise 10 and installed on a domino 6.0.3 server.There are two main problem
Problem #1
The installation part when Ok I left all the defaults just to make sure everything work ok. Then I restart the machine. I saw the two virtual directories made by Cristal Reports then I open the web browser as http://webserver/crystal and I see the web page to navigate, but the configuration part does not work at all, I call Crystal Support and they told me to enter the following link http://mars/crystal/enterprise10/admin/en/admin.cwr which in turn openned the Admininistration window. they also send me the following message:
" Here are the links that you require to re-map the software. I
hope this helps to fix the problem and that you can get everything working
by the end of the week.
ADMIN
http://webserver/crystal/enterprise10/admin/en/admin.cwr - substitute
your webserver name where it says “webserver”
ONLINE VIEWER
http://webserver/crystal/enterprise10/ePortfolio/en/logonform.csp "
but I map those directories and still crystal redirection on themselves does not work.
Problem #2
Now I decide to see if at least I can see a report, and I type the following
http://webserver/crystal/report1.rpt
and I get the following error
"Error encountered by Crystal Page Server
The error message returned is:
Internal error. [On Cache/Page Server: webserver]"
No solution yet but please if you know anything about this problem please let me know.
Subject: Crystal Enterprise 10 Installation Problems
Ricardo - did you get this working? I am curious to how is Crystal working with Domino 6 (I am assuming you are using DSAPI)?
Thanks,
Jerry T
