Dear all,
I created two Notes Domain, for example: one is @TEST and another is @TEST1. Also I
created Organization cert /TEST under @TEST and /TEST1 under @TEST1. Then I begin
my cross certification process. I created two safe ID for two O-cert /TEST and /TEST1.
Then I copy safe ID of /TEST to domain @TEST1 and copy safe ID of /TEST1 to domain @TEST.
After cross certification processed is completed. I see that there is “Notes Cross Certificates”
view under Certificates view in Names and Address Book. Although when I issued trace command
on one Domino server. it is said that “authentication failed: public names and address is not found”.
users and servers in domain TEST cannot access domain TEST1 and vice versa. I also tried
to use cert ID (not safe ID) for cross certification but the result is the same. I wonder
there is some steps I miss out or not. I also checked security setting in server document and include
server name of other notes domain.
What is the normal step for cross certificates for following cases ?
Cross certify two O-certs under the same notes domain (Org1/TEST@TEST, Org2/TEST@TEST)
Cross certify two O-certs under different notes domain (Org1/TEST@TEST, Org2/TEST1@TEST1)
The following technote is my reference for cross certificate
Did I omit or miss some steps to further complete cross-cert process ?
Tom Cheung
12 Nov 2008
