Creating Invitations using Visual Basic - please help!
Hi all,
kinda banging my head against the wall here, and could do with some advice.
I am trying to write a piece of VB (it will be ASP eventually) which will take a set of data (meeting title, start time, attendee email addresses, etc) from our app, and interface with Lotus Notes to create a Lotus Notes Meeting/Invitation and then send out the Invitation to the Attendees via Lotus Notes e-mail. Ideally, we would like to allow the user to be able to manually edit the Invitation before it is sent to the Attendees, but I think that’s a bit far away at the moment.
So, I am using the Notes COM Toolkit to do this, and have now ran into a wall. Although I am able to create the Meeting within my personal notes database, Notes NEVER sends the Invitation to any of the listed Attendees, no matter if I edit the Meeting within Notes itself. It is basically useless.
Earlier today, I discovered the NotesDocument.Send method, which helped me a little. My Invitations are now sent to the Attendees, but when opened in Notes, are not in ‘Invitation’ format, and are instead presented as a standard plain text email, with no ‘Accept’, ‘Deny’-type buttons.
Also, if I then rerun my VB routine a second time, I get a “-2147217461 - Database Open Failed (%1)” error - not helpful. Removing the call to Send() eliminates the error.
So I ask:
  1. Do I have to use the Send() method to get the Invitations sent out? If so, any ideas about this “-214…” error?
  2. How do I get the sent message to appear as an Invitation rather than just a standard bloody email!?
So frustrating for something so simple!
Here is my routine:
Sub CreateNotesMeeting()
On Error GoTo ErrorHandler
Dim objNotesSession As NotesSession
Dim objNotesDbDirectory As NotesDbDirectory
Dim objNotesDatabase As NotesDatabase
Dim objNotesDocument As NotesDocument
Dim objNotesDtFrom As NotesDateTime
Dim objNotesDtTo As NotesDateTime
Dim objNotesRichTextItem As NotesRichTextItem
Set objNotesSession = New NotesSession
Call objNotesSession.Initialize
Set objNotesDbDirectory = objNotesSession.GetDbDirectory("")
Set objNotesDatabase = objNotesDbDirectory.OpenMailDatabase()
'Set objNotesDatabase = objNotesSession.GetDatabase("", "mail\amcnab.nsf")
Set objNotesDocument = objNotesDatabase.CreateDocument
Set objNotesDtFrom = objNotesSession.CreateDateTime("2004-04-21 15:00:00")
Set objNotesDtTo = objNotesSession.CreateDateTime("2004-04-21 16:00:00")
Set objNotesRichTextItem = objNotesDocument.CreateRichTextItem("Body")
'## Appointment Type - Meeting
Call objNotesDocument.ReplaceItemValue("AppointmentType", "3")
'## General Meeting Info
Call objNotesDocument.ReplaceItemValue("Form", "Appointment")
Call objNotesDocument.ReplaceItemValue("Subject", "Test Meeting 3 Subject")
'commented line replaced with mulit-line body example
'Call objNotesDocument.ReplaceItemValue("Body", strBody)
objNotesRichTextItem.AppendText ("This is line 1")
objNotesRichTextItem.AddNewLine
objNotesRichTextItem.AppendText ("This is line 2")
Call objNotesDocument.ReplaceItemValue("Location", "Test Meeting 3 Location")
Call objNotesDocument.ReplaceItemValue("Room", "Test Meeting 3 Room")
'## Who sent/created/chairs the Meeting
Call objNotesDocument.ReplaceItemValue("From", objNotesSession.UserName)
Call objNotesDocument.ReplaceItemValue("Chair", objNotesSession.UserName)
'## Time of meeting-related stuff
Call objNotesDocument.ReplaceItemValue("STARTDATETIME", objNotesDtFrom)
Call objNotesDocument.ReplaceItemValue("EndDateTime", objNotesDtTo)
Call objNotesDocument.ReplaceItemValue("CalendarDateTime", objNotesDtFrom)
Call objNotesDocument.ReplaceItemValue("StartTime", objNotesDtFrom)
Call objNotesDocument.ReplaceItemValue("EndTime", objNotesDtTo)
Call objNotesDocument.ReplaceItemValue("StartDate", objNotesDtFrom)
Call objNotesDocument.ReplaceItemValue("EndDate", objNotesDtTo)
'## Attendee-related data
Dim arrRequiredAttendeeName() As String
Dim arrRequiredAttendeeNameAndEmail() As String
arrRequiredAttendeeName = Split("XXX@XXX.com", ";", -1)
Call objNotesDocument.AppendItemValue("RequiredAttendees", arrRequiredAttendeeName)
Call objNotesDocument.AppendItemValue("AltRequiredNames", arrRequiredAttendeeName)
'Call objNotesDocument.AppendItemValue("INetRequiredNames", arrRequiredAttendeeNameAndEmail)
Call objNotesDocument.ReplaceItemValue("StorageRequiredNames", ".")
Call objNotesDocument.AppendItemValue("SendTo", arrRequiredAttendeeName)
Call objNotesDocument.AppendItemValue("NoticeType", "I")
'## System variables
Call objNotesDocument.ReplaceItemValue("$UpdatedBy", objNotesSession.UserName)
Call objNotesDocument.ReplaceItemValue("_ViewIcon", 158)
'Call objNotesDocument.ComputeWithForm(False, False)
Call objNotesDocument.Send(True, arrRequiredAttendeeName)
Call objNotesDocument.Save(True, True)
Set objNotesRichTextItem = Nothing
Set objNotesDtTo = Nothing
Set objNotesDtFrom = Nothing
Set objNotesDocument = Nothing
Set objNotesDatabase = Nothing
Set objNotesDbDirectory = Nothing
Set objNotesSession = Nothing
Exit Sub
ErrorHandler:
MsgBox Err.Number & " - " & Err.Description
Subject: Creating Invitations using Visual Basic - please help!
My recommendation is to look at what is left behind on an invitation document within lotus notes. If you need to create an invitation within Lotus Notes using the “Island” location document. After you note those field you will be able to have a base for your VB code. I wonder if any of the field do not have the correct field type.
Did the appointment show up on the invitee’s calendar?
HTH – Cheers
Andrew,
Here is a function that I created in one of my notes applications to create a
document of the meeting invitation type. It works fine on R5 and I think It
successfully passed my tests on 6,5 as well.
u>Notes ]
I do not know what half of the fields are for but some of them must exist;
others don’t and I just don’t know which ones are mandatory.
I deleted some additional code which are not relevant for the invitation itself
so you may see some declarations of variables that are not used.
Good luck.
Function MakeMeetingInvitation(docCur As NotesDocument, nmUserChair As
notesName , nmUserFrom As notesname, _
nmUserTo As NotesName) As NotesDocument
'This function creates a meeting invitation
Dim s As New notessession
Dim db As NotesDatabase
Dim docSession As NotesDocument
Dim docInvitation As notesdocument
Dim vrnStartDate As Variant
Dim vrnEndDate As Variant
Dim vrnStartTime As Variant
Dim vrnEndTime As Variant
Dim strLocation As String, strSessionInfo As String
Set db = docCur.parentDatabase
'Getting information from Session sDocument
Set docSession = GetParentDocument(db, docCur.ParentDocumentUNID)
If Not docSession Is Nothing Then
	strLocation = docSession.Session_Loc(0)
	strSessionInfo = docSession.Session_Subject(0)
'Set nmUser = New NotesName (s.Username)
Set nmUserFrom = New NotesName("Learning&Education")
' READING DATE AND TIME FIELDS
'it is not necessary to use variable but it makes it easier to debug
vrnStartDate = Datevalue(docCur.Session_StartDate(0))
vrnEndDate =  Datevalue(docCur.Session_EndDate(0))
vrnStartTime = Timevalue(docCur.Session_StartTime(0))
vrnEndTime = Timevalue(docCur.Session_EndTime(0))
' CREATING INVITATION
Set docInvitation = db.createDocument
docInvitation.Form = "Notice"
docInvitation.~_ViewIcon = 133
docInvitation.~$PublicAccess = "1"
docInvitation.AppointmentType = "3"
docInvitation.AltChair = nmUserFrom.Abbreviated
docInvitation.AltRequiredNames = nmUserTo .Abbreviated
docInvitation.AltSendTo = nmUserTo.canonical + "@EMEA-BE"
'Chair cannot be the same as User and UserFrom or the accept buttons
will not be visible. it cannot be empty either
docInvitation.Chair = nmUserChair.canonical
docInvitation.Location = strLocation
docInvitation.NoticeType = "I"
docInvitation.PostedDate = Now
docInvitation.Principal = nmUserFrom.canonical
docInvitation.RequiredAttendees = nmUserTo.abbreviated + "@EMEA-BE"
docInvitation.Subject = "Invitation : " + docCur.Course_Name(0)
docInvitation.SendTo =nmUserTo.canonical
docInvitation.StartDate = vrnStartDate + vrnStartTime
docInvitation.StartDateTime = vrnStartDate + vrnStartTime
docInvitation.StartTime = vrnStartDate + vrnStartTime
docInvitation.EndDate = vrnEndDate + vrnEndTime
docInvitation.EndDateTime = vrnEndDate + vrnEndTime
docInvitation.EndTime = vrnEndDate + vrnEndTime
docInvitation.Topic = docCur.Course_Name(0)
Dim strarrCSTrack(1) As String
strarrCSTrack(0) = "InitEventDescriptorFromNewNote by Notes Client on "
  • nmUserFrom.Abbreviated + “(” & Trim(s.NotesVersion) & ") at " & Cstr(Now)
    strarrCSTrack(1) = "SendPrimaryMeetingRequest by Notes Client on " +
    docInvitation.~$Alarm = 1
    docInvitation.~$AlarmOffset = -30
    docInvitation.~$AltPrincipal = nmUserFrom.canonical
    docInvitation.~$CSTrack = strarrCSTrack
    docInvitation.~$CSVersion = “2”
    docInvitation.~$ExpandGroups = “3”
    docInvitation.~$LangChair = “”
    docInvitation.~$LangPrincipal = “”
    docInvitation.~$Mailer = "Lotus Notes " + Strleft(s.notesVersion, “|”,
    • " " + Trim(Strright(s.notesVersion, “|”, 1))
      docInvitation.~$NameLanguageTags = “en”
      docInvitation.~$NoPurge = vrnStartDate + vrnStartTime
      docInvitation.~$StorageTo = “1”
      docInvitation.~$StorageCc = “”
      docInvitation.~$SMTPKeepNotesItems = “1”
      docInvitation.~$WebFlags = “J”
    Dim itemSign As NotesItem
    Set itemSign = New NotesItem(docInvitation, “Sign”, “0”)
    docInvitation.Alarms = “1”
    docInvitation.AltCopyTo = “”
    docInvitation.APPTUNID = docInvitation.universalID
    docInvitation.BookFreeTime = “”
    docInvitation.CopyTo = “”
    docInvitation.FromCategories = “”
    docInvitation.INetSendTo = “.”
    docInvitation.INetCopyTo = “”
    docInvitation.INetRequiredNames = “.”
    docInvitation.Logo = “stdNotesLtr0”
    docInvitation.MailFirstPass = “1”
    docInvitation.MAILOPTIONS = “”
    docInvitation.OrgConfidential = “”
    docInvitation.Repeats = “”
    docInvitation.RoomToReserve = “”
    docInvitation.Resources = “”
    docInvitation.SequenceNum = 1
    docInvitation.StorageRequiredNames = “1”
    docInvitation.WebCategory=“”
    docInvitation.WebDateTimeInit = “1”
    'No Counter proposal + No responses
    docInvitation.Broadcast = “1”
    'docInvitation.PreventCounter = “1”
    Set MakeMeetingInvitation = docInvitation
End Function
