Create System DSN using LotusScript, Working sample
Here’s a script for all of you who want your Notes-clients to be able to create a DSN in order for ODBC-connections to work.
Put the code in a button in your applications and the clients can create it themselves.
Sub Initialize
On Error Goto errhandle
Dim DataSourceName As String
Dim DatabaseName As String
Dim Description As String
Dim DriverPath As String
Dim DriverName As String
Dim LastUser As String
Dim Regional As String
Dim Server As String
Const SystemFolder= 1
Dim WshShell As Variant
Dim fso As Variant
Dim SysFolder As Variant
Dim SysFolderPath As String
Set WshShell = CreateObject("WScript.Shell")
Set fso = CreateObject("Scripting.FileSystemObject")
Set SysFolder = fso.GetSpecialFolder(SystemFolder)
SysFolderPath = SysFolder.Path
'Specify the DSN parameters.
DataSourceName = "Your source name"
DatabaseName = "Your default database name"
Description = "Your Short descripion of DSN"
DriverPath = SysFolderPath & "\sqlsrv32.dll"
Server = "Your IP-adress or servername"
LastUser  = "Your database Username"
DriverName = "SQL Server"
Dim RegEdPath
RegEdPath= "HKLM\SOFTWARE\ODBC\ODBC.INI\" & DataSourceName & "\"
WshShell.RegWrite  RegEdPath  , ""
WshShell.RegWrite  RegEdPath & "Database" , DatabaseName
WshShell.RegWrite  RegEdPath & "Description" , Description
WshShell.RegWrite  RegEdPath & "Driver" , DriverPath
WshShell.RegWrite  RegEdPath & "LastUser" , LastUser
WshShell.RegWrite  RegEdPath & "Server" , Server
WshShell.RegWrite "HKLM\SOFTWARE\ODBC\ODBC.INI\ODBC Data Sources\" & DataSourceName , DriverName
Msgbox "Successfully created DSN"
cleanup:
Set WshShell = Nothing
Set fso = Nothing
Set sysFolder = Nothing
Exit Sub
errhandle:
Msgbox Error() & " on row " & Erl() & " in Sub initialize()"
Goto cleanup
Subject: Create System DSN using LotusScript, Working sample
Wow, thanks. I was looking for this code about 3 weeks ago and couldn’t find it. Much appreciated.
