I have creating a database on the fly using Lotus Script. Is it possible to create an index for the documents in the database as well, so that it is searchable??
Please advice.
Please advice.
Subject: Create index using Lotus Script
Consider creating a database on the fly from a template - then Yes; this can be done from LotusScript.
Take a look at the methods .Create and .CreateFromTemplate in the NotesDatabase class.
Then to enable the Fulltext-index; call the .UpdateFTIndex method in the NotesDatabase class.
hth
