Copying and pasting help
Part of a database we have allows users to select multiple documents and then hit a button which brings up a form and allows them to enter a ‘standard response/answer’ for those questions.
The code behind this fills in some respective fields on the response documents (eg, question number etc). The code also creates a word document which attaches itself to the response document and fills into the word document what the users had entered in the ‘standard response/answer’ field.
What I’d like to do is get rid of the Word document and just have the ‘standard response/answer’ get filled into a form on the response document itself. The code at the moment copies the response from a temporary field into the clipboard and then pastes it back into the word document. The code which copies the text is shown below (it does this on QueryClose):
Sub Queryclose(Source As Notesuidocument, Continue As Variant)
Dim Workspace As New NotesUiWorkspace
Dim Session As New NotesSession
Dim SelectedQuestions As NotesItem
 '// If the user presses cancel then dont do anything
If Source.Document.CreateDocuments(0) = "No" Then
	Exit Sub
 '// Copy the Entered Text and place it into the clipboard
Call Source.GotoField("StandardResponse")
On Error Goto InsertAndCopyDummyText
Call Source.SelectAll()
Call Source.Copy()
On Error Resume Next
 '// Begin Creating the Advice for each selected Document
Set SelectedQuestions = Source.Document.GetFirstItem("SelectedQuestions")
 '// Create the Advice Documents
If (Source.Document.DocumentType(0) = "Advice") Then
	Call CreateBulkAdviceForMany(SelectedQuestions)
Else
      '// Create the Answer Documents
	Call CreateBulkAnswerForMany(SelectedQuestions)
Exit Sub
InsertAndCopyDummyText:
Call Source.InsertText(" ")
Resume
This is the code which creates the actual answer form - I’d like to use code here to somehow paste what’s on the clipboard into a field in the answer document. I’m not sure how to navigate to the field I want and then paste it in. The code I’ve looked at for pasting only talks about uidocument, which I don’t think will work for me.
Sub CreateAnswer(SelectedQuestions() As String, AdviceDocument As NotesDocument, PasteAnswer As Integer)
Dim WorkSpace As New NotesUiWorkSpace
Dim QuestionsAnswered As NotesItem
Dim QuestionsAnsweredFullName As NotesItem
Dim QoNDatabase As NotesDatabase
Dim NewAnswerDocument As NotesDocument
Dim AnswerText As NotesRichTextItem
Dim Added(0) As String
Dim AuthorsList As NotesItem
Dim ReadersList As NotesItem
Dim QuestionCount As Integer
Dim QuestionDocument As NotesDocument
 '// Get the current database
Set QoNDatabase = Session.CurrentDatabase
 '// Create the new Answer document
Set NewAnswerDocument = New NotesDocument(QoNDatabase)
NewAnswerDocument.Form = "Answer"
NewAnswerDocument.AnswerStatus = "Creation"
NewAnswerDocument.AuditTrail = ""
NewAnswerDocument.CreationDate = Now()
Call PopulateAnswerIDNumber(NewAnswerDocument)
Set AuthorsList = New NotesItem(NewAnswerDocument, "AuthorsList", Session.UserName, AUTHORS)
Set ReadersList = New NotesItem(NewAnswerDocument, "ReadersList", Session.UserName, READERS)
 '// Is it a Bulk Answer?
NewAnswerDocument.BulkAnswer = "Y"
NewAnswerDocument.DocumentSaved = "Y"
 '// Get the Question document details using the Universal ID
For QuestionCount = 0 To Ubound(SelectedQuestions())
      '// Get each Question document details
	Set QuestionDocument = GetDocumentByUNID(SelectedQuestions(QuestionCount))
	Redim Preserve ParliamentNumberList(QuestionCount)
	Redim Preserve SessionNumberList(QuestionCount)
	Redim Preserve HouseRaisedInList(QuestionCount)
	Redim Preserve QuestionNumberList(QuestionCount)
	Redim Preserve QuestionDetailsList(QuestionCount)
	QuestionNumberList(QuestionCount) = QuestionDocument.QuestionNumber(0)
	HouseRaisedInList(QuestionCount) = QuestionDocument.HouseRaisedIn(0)
	ParliamentNumberList(QuestionCount) = QuestionDocument.ParliamentNumber(0)
	SessionNumberList(QuestionCount) = QuestionDocument.Session(0)
	QuestionDetailsList(QuestionCount) = Cstr(Cstr(ParliamentNumberList(QuestionCount)) + _
	"/" + SessionNumberList(QuestionCount) + "/" + HouseRaisedInList(QuestionCount) + _
	"/" + QuestionNumberList(QuestionCount))
Next
 '// Set the default Questions Answered values to the SelectedQuestions
Set QuestionsAnswered = New NotesItem(NewAnswerDocument, "QuestionsAnswered", "")
NewAnswerDocument.QuestionsAnswered = QuestionDetailsList
Set QuestionsAnsweredFullName = New NotesItem(NewAnswerDocument, "QuestionsAnsweredFullName","")
Call UpdateFullNameQuestionList(NewAnswerDocument, QuestionsAnswered, QuestionsAnsweredFullName)
 '// Make it a response of the question document
Call NewAnswerDocument.MakeResponse(QuestionDocument)
If Not(AdviceDocument Is Nothing) Then
      '// Save the AnswerDocument so that it allows the addition of a rich text field.
	Call NewAnswerDocument.Save(False, False)
      '// Add the attachment
	Call AddPrevAdviceTemplateToAnswer(AdviceDocument, NewAnswerDocument)
If PasteAnswer Then
      '// Add the rich text
	Set AnswerText = New NotesRichTextItem(NewAnswerDocument, "AnswerText")
      '// Save the Answer Document so we can add a rich text field
      '// Create and Embed the OLE Object
	Call CreateAndEmbedOLEAdvice(QuestionDocument, NewAnswerDocument, AnswerText)
 '// Add the Link to the Document
Added(0) = Cstr(QuestionDocument.ParliamentNumber(0)) + "/" + Cstr(QuestionDocument.Session(0)) + "/" + _
Cstr(QuestionDocument.HouseRaisedIn(0)) + "/" + Cstr(QuestionDocument.QuestionNumber(0))
 '// Set the Access Lists
Call SetAnswerAccessLists(NewAnswerDocument)
HOpe this all makes sense. I’m not sure if I should be looking at doing this another way besides copying and pasting text from the clipboard.
Thanks.
