I have a client that needs to convert all her contacts from ACT into Lotus Notes. Does anyone know of a hopefully simple way this can be done? Or as simple as possible.
Thank you
Dianna
Thank you
Dianna
Subject: Converting Contacts from ACT
Export the contacts from ACT and then import them into Lotus Notes --maybe the address book since you did not state where to import them.
You may have to give a COL file for the import so it would know which value will go to a specific field.
HTH – Cheers
There is ACT for notes, check with them if they have a conversion tool already,
else you will have to write an import/export routine either using spreadsheets or script.
if you need further help let me know, I have done a lot of inter application conversions.
Subject: RE: Converting Contacts from ACT
Act for notes is not 100% compatible with ACT the stand-alone product. These products are made by 2 different companies. While some functionality is compatible, there are a lot of features not compatible. I would go to the export import and not waste time with ACT for Lotus Notes unless you are going to use the product as a replacement for ACT.
HTH – Cheers
I wrote this code to migrate act contacts from an ACT database to a notes document. I recommend using the ACT API for additional reference.
Dim db As NotesDatabase
Set db = session.currentdatabase
Dim contactdoc As NotesDocument
Dim actview As NotesView
Set actview = db.GetView(“luByActId”)
Dim ACTId As String
Dim appflag As Boolean
'check and see if they want to specify the .dbf file to import, or they have only one file which the system will find.
If Messagebox("Do you have more than 1 ACT Database to import?", MB_YESNO + MB_ICONQUESTION) = IDYES Then
FileName = OpenCommDlg
Set objDatabase = CreateObject("ACTOLE.DATABASE")
objDatabase.Open FileName
Else
Set objApplication = CreateObject("ACTOLE.APPOBJECT")
objDatabase.Open objApplication.GetOpenDBName
objApplication.Minimize
appflag = True
If objDatabase.IsMultiUser Then
Dim username As String
Dim password As String
username = Inputbox("Please Enter a User Name")
password = Inputbox("Please Enter a Password")
objDatabase.validateuser username, password
Dim counter As Long
counter = 0
Dim pp As Integer
If objDatabase.IsOpen Then
Set objContact = objDatabase.CONTACT
If objContact.recordCount > 0 Then
objContact.MoveFirst
While Not objContact.IsEOF
If objContact.Data(CF_PublicPrivate) = 1 Then
counter = counter + 1
Print "Importing Record " & counter & " of " objContact.recordCount
ACTId = objContact.Data(CF_UniqueID)
Set contactdoc = actview.GetDocumentByKey(ACTId, True)
If contactdoc Is Nothing Then
Set contactdoc = db.createdocument()
contactdoc.ACTUniqueID = objContact.Data(CF_UniqueID)
contactdoc.Form = "Prospect"
contactdoc.ContactStatus = "Prospect"
contactdoc.CompanyName = objContact.Data(CF_Company)
contactdoc.ContactName = objContact.Data(CF_Name)
contactdoc.ContactTitle = objContact.Data(CF_Title)
contactdoc.ContactDepartment = objContact.Data(CF_Department)
contactdoc.ContactPhoneOffice = objContact.Data(CF_Phone)
contactdoc.ContactPhoneFax = objContact.Data(CF_Fax)
contactdoc.ContactPhoneCell =objContact.Data(CF_MobilePhone)
contactdoc.ContactSalutation = objContact.Data(CF_Salutation)
contactdoc.WebSite = objContact.Data(CF_URL)
contactdoc.CompanyAddressL1 = objContact.Data(CF_Address1)
contactdoc.CompanyAddressL2 = objContact.Data(CF_Address2)
contactdoc.CompanyAddressL3 = objContact.Data(CF_Address3)
contactdoc.CompanyCity = objContact.Data(CF_City)
contactdoc.CompanyState = objContact.Data(CF_State)
contactdoc.CompanyZip = objContact.Data(CF_Zip)
contactdoc.CompanyCountry = objContact.Data(CF_Country)
contactdoc.ContactEmail = objContact.Data(CVF_EmailAddress)
Call contactdoc.save(True,True)
objContact.MoveNext
Wend
Set objContact = Nothing
objDatabase.Close
If appflag Then
objApplication.CloseDB
