Controlled access section problem
I have a controlled access section Type=Computed for display
The formula produces a list of names and the [Admin] role
Even though users are listed and/or in the Admin role, they cannot edit the section.
Any ideas ???
TIA,
Mark.
Subject: Controlled access section problem
This is a guess, but try Computed, rather than Computed for Display.
Subject: RE: Controlled access section problem
OK thanks worth a try
I agree…try changing it to computed. I know this could be a stupid question but do these users have access to edit the document (ie…in the docAuthors field and in the ACL)?
And are in they enclosed in Quotes and separated with a colon. “User1” : “User2”
These may be obvious but you never know.
Yes to both. Thanks i will try it out
Thanks guys that worked great :slight_smile:
