Connection Split - Hide Wikis and Blogs
we are currently executing a project where we split a Connections instance into 2 because of company separation.
This is done by duplicating the instance and the database. After the split, every content not belonging to company 2 should be hidden to restore it easily when someone decides that the content is relevant for company 2.
For communities, we remove all members and set them private.
Public Stand Alone Activities and Stand Alone Forums will be trashed. (Trash deletion is set to 180Days)
For Blogs and Wikis, we are still looking for a possible solution as these features have no trash. (Wiki pages have but not whole wikis.)
In the Blogs Database, I found a flag "isEnabled" when set to 0 the blog is not accessible anymore.
In the Wikis Database, I found a flag "state" which seems to be set for community wikis set to 1 when the community is deleted. For Stand Alone Wikis it seems to have the same effect.
Now my question: Does anymore know if there are any side effects when using these flags?
I know it is not supported and later, the content has to be really deleted (maybe by API).
Martin
