I’m trying to connect from the lotus notes domino server 8.5 to the notes sql data source. I have installed notessql 8.5.
the error is "Lotus notes sql driver ODBC driver could not be loaded due to system error code 126
pls. help
thanks
pls. help
thanks
Subject: Connection Problem using lotus notes sql data source
you need to put the notes.ini file path in your environment path variable.
