Hi!I have a form where users register numbers in a field called “patients” (numberstype field). On a different form I have a computed field (PP) which summons all values from the “patient”-fields. This is working Ok, the problem I have i how to get the computed “PP”-value into a view-column. I have tried to select that field as a column value but no numbers apper even if I have selected the proper form in “View selection”, how do I solve this? Thanks in advance!
Subject: computed-for-display?
Please check if your computed field (PP) is computed-for-display. If it is, you can not use its values in a view because the values are not saved.
Phil
Subject: Computed fieldvalue in a column
Hi!No, it´s not a computed for display-field, just computed.
