Compression data network doesn´t work
Hi
I turned on the Compression Network Data to Port TCPIP, but I don´t see performane with it. Do I forgot to do something more?.
Thanks in advanced.
Regards.
Subject: Compression data network doesn´t work
Jorge,
Where did you turn it on? It must be on both ends (client/server or server/server to work).
Jeff Dayton, PCLP, CLI
Subject: RE: Compression data network doesn´t work
Jeffrey
First thanks for your answer. I did it only on Server Settings (Server - Setup - Ports). We did LAN trafic test between Client and server. do I must to setup client?, where do I can do it?
Thanks a lot.
Jorge,
Search for “compression” in Notes Client Help. The answer is there for you.
Thanks a lot Jeffrey
Regards
