@Compose and PostOpen database script problem!
I want to compose a new document when the database is create.
I try using:
@Command([Compose];“Group”)
@PostedCommand([Compose];“Group”)
@Command([Compose];“”;“Group”)
@Command([Compose];@DBName;“Group”)
but Nothing is working!
I always get the error message “Invalid or nonexistent document”.
I try different form, same error. I use the same code bellow in a button an it’s workinf fine.
Any idea?
Thank you!
Alexandre
Subject: @Compose and PostOpen database script problem!
Sorry, i means when the database is open!
