Can someone give me a quick tip on my compacting problem.
When I compact my mailbox on server, size of mailbox does not change, but the local replica of mailbox is compacted properly.
Please advise what to do to have server replica compacted as well.
Thanks for help, Sam
Subject: Compacting problem
Hi Sam, Note Compacting a database does NOT reduce its size.It merely recovers unused space so the database can operate most efficiently.
Further read the note below:
When you compact a local database, Notes may need to make a temporary copy of it depending on necessary internal structural changes. To allow for that possibility, you should make sure that there is sufficient disk space to store the temporary database copy during that process. Compacting a database retains the read marks users see and the existing view indexes
