I have two frames. Left hand frame contains a view with documents, right hand frame contains the document content. The default target for the content frame is itelf i.e. if you edit a document it is edited within the frame. However, we seem to have identified a bug. There is one button which does an @Command([FileSave]). This always saves the document but reverts the document to read mode. Doing Ctrl-S or File-Save does exactly the same thing. Anything that is saved in the content frame ALWAYS reverts to read mode. This problems exists in R5 and R7 (assume R6 is the same). Anyone come across this and/or have a solution?
There are no other events on the form that could affect this i.e. it is a very simple form design.
