So… I’ve upgraded a few clients here from 8.0.2 to 8.5.1, and I found a HUGE issue.
I have several agents that export data from views to files, and then process the data.
It appears that the functionality of @Command([FileExport];“Tabular Text”) has change.
In release 8.0.2 and previous the values from the view were exported with spaces between them. It now appears in Notes 8.5.1 that TABs are used as a deliminator.
This is a huge problem and appears to be undocumented. Any help restoring the original functionality without downgrading or recoding would be much appreciated.
We are experiencing the same problem - testing 8.5.1 FP2 client and have issues with applications which use the @Command([FileExport];“Tabular Text”), the .csv files created open in excel with tabs instead of spaces.
