I create a new empty form with only a button containing the following formula, using the new v6 command functions that are supposed to execute immediately:
SetField(“Foo”;“Somevalue”)
@Command([FileSave]);
@Command([RunAgent]; “(SomeAgent)”);
@Command([CloseWindow])
“SomeAgent” does not contain any code, with target “None”.
Now, when I push the button on a new document, I get the “Do you want to save your changes?” message.
And at the moment when the agent is run, the document has not been saved yet.
Wrapping the commands in a @Do or checking the return of the save (with an @If) before continuing does not change anything.
Could anyone please explain this?
Thanks all.
