Hi
I am using a button with the following formula. Its a simple formula to access a network share
@Command([Execute]; “cmd”; “/k net use \10.2.10.19\ipc$”)
I get the reply that the server name is invalid. The \ before the ipc$ disappears whenever i press the button.
If i type this command on the command line, it works fine.
On the other hand if i use the formula
@Command([Execute]; “cmd”; “/k ipconfig /all”) it works
Am i entering something wrong?
