Comma Problem
In the code i am handling dynamic array of size 5. The original size of the array can be 1,2 on ocassions. When i assign the array to a value in the document, i am getting the output as
A,B,
I want to display only values. I dont want the Comma’s when there is no value.
In the above case i want output to be A,B
Can anyone help me on this.
Thanks in Advance
Subject: Comma Problem
please post your code
If you are doing this in LotusScript, then try this
doc.Fieldname = fulltrim(array)
That should remove the empty elements of the array.
Subject: RE: Comma Problem
Thanks Jerry. It worked.
