Combining a MIME Entity with a Mail Memo's Body Field
I’m trying to put some HTML into every outgoing email my client sends (formatted text and a URL reference to an image on the corporate server).
Thanks to Rod Whitely, I’ve figured out to get HTML in an outbound email using CreateMIMEEntity. But the code I use to do this tries to create a brand new Body field, which of course results in an error (Item body already exists) when it runs since there’s already a Body field on the Memo.
How do I concatenate the new MIME Entity with my existing Body field?
Here’s my sample code, in the QuerySave event of my memo:
Sub Querysend(Source As Notesuidocument, Continue As Variant)
Dim doc As NotesDocument
Set doc = Source.Document
htmltext$ = {My Company<br>
123 My St.
My Town, MyState 12345
Phone: 123-456-7890 Fax: 123-456-7891
Email: me@my_company.com
<img
src=“http://www.my_company.com/database.nsf/mylogo.jpg?openImageResource”
alt=“My Logo” border=“0”>}
 Dim html As NotesStream
 Set html = session.CreateStream
 html.WriteText htmltext$
 Dim mime As NotesMIMEEntity
 Set mime = doc.CreateMIMEEntity("Body")
 mime.SetContentFromText html, "text/html", ENC_NONE
I tried replacing it with this, in which I try to create different rich text and MIME entities and concanetate them, but it doesn’t work:
123 My St.
<img
Dim rtitem1 As Variant
Dim rtitem2 As Variant
Set mime = doc.CreateMIMEEntity("Body2")
Set rtitem1 = doc.GetFirstItem( "Body" )
Set rtitem2 = doc.ReplaceItemValue("Body", rtitem1 & Body2 )
Thanks very much in advance.
Subject: Combining a MIME Entity with a Mail Memo’s Body Field
Hello,I know your post is old and hope you still are present on this forum…
I have exactly the same problem and I don’t know how to combine an existing document to send out. I have the error message Item body already exists
Have you solved your problem ?
Thank you very much
Subject: Any reason for not using Actions, Tools, Preferences, Mail, Signature and specifying an HTML file?
Just a wild guess:
Instead of creating a Body field, why not use the existing Body field? (that is what you describe)
So instead of using CreateMIMEEntity, look at the method GetMIMEEntity in the designer help.
