Combine lists using script and make it unique
I have 2 fields in the currently open document values of which i need to combine and make the new list unique. How do I do that?
Subject: Combine lists using script and make it unique
assuming each field is multivalue:
Create an array out of each field’s values.
Use ArrayAppend to combine them into a new combined array.
Use ArrayUnique to remove any duplicate values.
Subject: RE: Combine lists using script and make it unique
Jessie is correct…
You can do that by using ArrayAppend and ArrayUnique…
According to my understanding you have two multi-value fields and you want to combine the values of both and make a new list.
Consider you have FieldA and FieldB
Your code would look like this
Dim varFieldA as variant
Dim varFieldB as variant
Dim varCombinedValue as variant
varCombinedValue =ArrayAppend(varFieldA,varFieldB)
varCombinedValue =ArrayUnique(varCombinedValue )
'—if the value needs to be set in a new field then u can use
call doc.ReplaceItemValue(fieldname,varCombinedValue)
HTH,
Thish.
