This problem has now been resolved, by the following steps:
Locate the nlsxbe.dll that should be used ( D:\651EN\Notes\nlsxbe.dll in my case )
Run regsvr32 -u nlsxbe.dll ( this is important, I think I didn’t do it before )
Run regsvr32 “D:\651EN\Notes\nlsxbe.dll”
Check the registry with regedit :
a) Look at :
HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Lotus.NotesSession
You will find the CLSID
b) Search the registry for this CLSID (class ID) :
HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{29131539-2EED-1069-BF5D-00DD011186B7}\InprocServer32
Then check that the value is the correct for default.
The path of the nlsxbe.dll file should be correct.
InprocServer32 is set to:
I am having the same problem. Have tried the following all the steps to unregister and register the .dll. THe problem still not resolved.
Something strange is that after I reboot the system, I am able to run the code without any error. After about an hour, the code will prompt with this error again.
Does anyone have any solution to this problem? I need to solution urgently as my company already migrated to Lotus Notes and all my programs needs to be updated and send the email notification via Lotus Notes.
I am using Visual Studio 2005 (VB.NET), IIS 6.0 and Lotus Notes Client 6.5.5 installed.
