Column icon righthand side is not visible
Hello,
Is it true that a column icon, newly designed, displays only the lefthand side if the column width is too small? The Notes-standard icons display in full, so I didn’t understand why mine didn’t work.
Maybe there’s already a fix for this?
Thanks for your thoughts!
Sjef
Subject: Column icon righthand side is not visible
To work properly, custom view icons need to be the suggested 11x13 pixels. Anything else is just asking for trouble.
Subject: RE: Column icon righthand side is not visible
Thanks for your response!
Indeed my image wasn’t 11x13, but 17x19, so I changed that. To no avail. So still, if you make your icon column as thin as possible in the Designer, you won’t see more than half of your custom view icons, whereas the Notes standard icons show properly.
I call it a bug…
Regards,
Sjef
