i am having problem when receive a new mail, normally when we receive a new mail the colour is " red". but now when i receive a new mail it automatic turn to “black” colour. so anyone know to go solve this problem ?
Subject: Color for incoming mail
Look at the advanced (propellerhead) tab of the database properties to see if the option “Don’t maintain unread marks” has been selected.
Subject: RE: Color for incoming mail
Ok. i already check the Advance properties. But it not allow me to check it because it was in invisible.
beside that “dont maintain unread mark” are there still any other possible?
okay. so should check or uncheck the “Don’t maintain unread marks”
It should be unchecked. That eliminates one possibility.
Thanks. it works
The mail database contains a profile document called ‘ColorProfile’. This profile document contains a field called $Sender1. If this field is empty or not available unread mail isn’t red but black. Unread mail can be recognized by the asterix in front of the email.
To correct this:
Fill the $Sender1 field in the profile ‘ColorProfile’ with $Name=“$profile_012colorprofile_” to:
PriName := @If(@IsAvailable(Principal) & Principal != “”; Principal; from);
AltName := @If(@IsAvailable($AltPrincipal) & $AltPrincipal != “”; $AltPrincipal; @IsAvailable(AltFrom) & AltFrom != “”; AltFrom; “”);
FromName := @LowerCase(@If(AltName != “”; PriName : AltName; PriName));
ChairName := @LowerCase(@If(@IsAvailable(AltChair) & AltChair != “”; Chair : AltChair; Chair));
IRName := @LowerCase(@If(@IsAvailable(AltIntendedRecipient) & AltIntendedRecipient != “”; AltIntendedRecipient : IntendedRecipient; IntendedRecipient));
LCfrom := @If(form = “Return Receipt”; IRName; form = “(ReplyNotice)”; ChairName; FromName);
list1 := “”;
list2 := “”;
list3 := “”;
S_1B := “00ffffff”;
S_1F := “00000000”;
S_2B := “00ffffff”;
S_2F := “00000000”;
S_3B := “00ffffff”;
S_3F := “00000000”;
color1 := S_1B : S_1F ;
color2 := S_2B : S_2F;
color3 := S_3B : S_3F;
@If(@Contains(LCfrom; list1) & list1 != “”; color1; @contains(LCFrom; list2) & list2 != “”; color2; @contains(LCFrom; list3) & list3 != “”; color3; “”)
