Client Problems ()
One of our departments is expeiencing a problem with most clients. The users are Notes using 6.0.1, Internet Explorer 6 and windows XP.Some of the users use Citrix (thin client) but everyone has the problem.
When they close lotus notes they get the first error:
‘the parameter is incorrect’.
Immediately followed by
‘you cannot quit notes because a dialog is active, switch to notes first, close the dialog and then exit notes’.
We have tried re-installing the clients bu it did not work.
Does anyone have any suggestions.
We will be upgrading to 6.5.4 but not for a month or so and we cannot wait.
Any help would be greatfully appreciated.
Tone Bloke
Subject: Client Problems () - a couple of thoughts…
This error is quite often related to document or database links. Are all affected users pointed to a startup database or default db via LotusScript?
Do you have any policy documents in play? perhaps with links to mobile directory catalogs etc?
Adam
