Checkboxes - Mulitple Values Problem
Hi
Can anyone help with the following problem.
I have a checkbox field named ‘Status’. This field contains values : N, P/A, BF, A, P, TBN.
The above values may contain further values in the future which will be added by the user.
My problem is that in my QuerySave method on the form I would like the user to assign a date to the ‘Reply Date’ field anytime the ‘status’ field contains the value ‘BF’.
This has to be in LotusScript.
I tried the following but it doesn’t take into account the situation of if more then 1 value is selected when ‘BF’ is selected.
Can anyone help please?
If source.fieldgettext("Status") = "BF" Then
	If continue <> False And source.fieldgettext("Status") = "BF" And source.fieldgettext("ReplyDate") = "" Then
		continue = False
		Messagebox "As this case has 'BF' status, you must enter a date by which a reply is expected.", 16, "Expected Reply Date"
		Call source.gotofield("ReplyDate")
Subject: RE: Checkboxes - Mulitple Values Problem
Try this:
dim doc as NotesDocument
dim item as NotesItem
dim flag as Boolean
set doc = Source.Document
set item = doc.GetFirstItem ( “Status” )
flag = false
forall v in item.Values
if v = “BF” then flag = true
end forall
if flag and Source.GetFieldText ( “ReplyDate” ) = “” then
and so on
Subject: Checkboxes - Mulitple Values Problem - THANKS !`
Klaus
Works a treat.
Many Thanks
Mick
