Checkbox display on web with multiple columns
Here’s how I solved it.
Add the following html code before your checkbox field (passing through html):
<tdwidth=“33%”>
Add the editable checkbox field set to one column and with the following formula
for your choices:
holdReasons := @DbColumn(“”;“”;“LookupReasons”;1);
holdReasons:=@If(@IsError(holdReasons);“”;holdReasons);
holdNum := @Elements(holdReasons);
REM {3 is the number of columns};
holdColNum := @Round(holdNum/3);
list:= “”;
@For(n:=1;n<=holdNum;n:=n+1;
a := @If(n=holdColNum;holdReasons[n]+"/font><td width="33%" valign="top"><font
size="2" face="Arial">]" + “|” + holdReasons[n] ;
@If(n=holdColNum*2; holdReasons[n]+"/font><td width="33%" valign="top"><font
holdReasons[n] + “|” + holdReasons[n]));
list:= @If(list=“”;a;list:a)
list
Add the following html code below your checkbox field to close the font,column,row
and table tags (passing through html).
