Hi there,I need a button the user can click and which tells him if “javaw.exe” is running or not. So I’d have to access the task-manager anyhow…is there a way to do this?
TIA,
Buzzy
TIA,
Buzzy
Subject: Check for running process?
Sure, using the Win32 API. The .BAS file in the zip here will give you what you need:
Subject: RE: Check for running process?
Nice!You don’t happen to have some LS-example for it ![]()
Buzzy
No, but it’s not difficult to rewrite, since VB and LS are very similar languages.
Yeah, you’re right - I’ll give it a try.
Thanks,
Buzzy
