Check box refresh problem
Dear all,i have about 10 check boxes on a form. when select one check box I use a function to deselect all the other checkboxes and do a calculation on another field. My problem is when i select one checkbox and click on the form it unclicks the checkbox and focus on the next checkbox.
what can i do to overcome this…thanks inadvance
shana
Subject: check box refresh problem…
Shana,
What is your function? Can you post it please?
Mike
