I’m trying to modify the Notes shortcut icon to add the ini parameter “=U:\Lotus\Notes\Data\Notes.INI”, yes I know running off a network share isn’t supported… I can get the parameter to add perfectly when I package using the Notes 8.5 Basic Client, but it won’t add to the Notes 8.5 Standard Client.
I hit on the idea of adding a new icon, this works and allows me to add the parameter. Great I thought to myself, but if I try to either remove the default shortcut under System Configuration or drop the rows from within Direct Editor, Shortcuts, neither method removes the default icon. I therefore have the working custom icon which I’ve added and the default icon which doesn’t work. Has anybody tried removing the default icons and if so, have you had this problem?
I can also reproduce this in 8.0.2, so am thinking that because of the eclipse client, the method of removing/changing the icon is different.
Thanks in advance,
Wayne
