Changing RTF fonts etc - duplicate fields problem
I have some code (posted below) which we use to make sure all our documents are in the correct font etc.
However I have just found out that the code doesn’t work if the RTF is over 64K (in which case Notes splits the information and creates a second field of the same name). In this instance only the text in the first instance is changed.
Can anyone help me amend my code, please …
Paul
Dim session As New notessession
Dim doc As NotesDocument
Set doc = Source.Document
Dim item As NotesItem
Dim itemType As Integer
Dim body As NotesRichTextItem
Dim nav As NotesRichTextNavigator
Dim range As NotesRichTextRange
Dim mmfontsize As NotesRichTextStyle
Set mmfontsize = session.CreateRichTextStyle
Dim mmfontface As NotesRichTextStyle
Set mmfontface = session.CreateRichTextStyle
Dim mmfontul As NotesRichTextStyle
Set mmfontul = session.CreateRichTextStyle
Dim rts As NotesRichTextSection
Forall items In doc.Items
	If items.Type = 1 Then
		Set body = doc.GetFirstItem(items.Name)
		Set nav = body.CreateNavigator
		Set range = body.CreateRange
		mmfontsize.FontSize = 9
		mmfontface.NotesFont = body.GetNotesFont("Arial",True)
		mmfontul.Underline = False
’ go through section headings
		If nav.FindFirstElement(RTELEM_TYPE_SECTION) Then
			Do
				Set rts = nav.GetElement
				If rts.TitleStyle.Underline = True Then
					Call rts.SetTitleStyle(mmfontul)
					Call rts.SetTitleStyle(mmfontsize)
					Call rts.SetTitleStyle(mmfontface)
				If rts.TitleStyle.FontSize > 9 Then
				If rts.TitleStyle.NotesFont <> body.GetNotesFont("Arial",True) Then
			Loop While nav.FindNextElement(RTELEM_TYPE_SECTION)
’ go through text runs
		If nav.FindFirstElement(RTELEM_TYPE_TEXTRUN) Then
			Do
				range.SetBegin nav
				range.SetEnd nav
				If range.Style.FontSize > 9 Then
					Call range.SetStyle(mmfontsize)
				If range.Style.NotesFont <> body.GetNotesFont("Arial",True) Then
					Call range.SetStyle(mmfontface)
				If range.Style.Underline = True Then
					Call range.SetStyle(mmfontul)
			Loop While nav.FindNextElement(RTELEM_TYPE_TEXTRUN)
End Forall
Call doc.Save(True,True)
Subject: Changing RTF fonts etc - duplicate fields problem
You are using doc.GetFirstItem and this is what the designer’s help say about it:
If multiple items in a document have the same name, programmatic access is limited to the first item. The remaining items yield invalid data. A work-around is to get the first item, process it, remove it, again get the first item (which was the second item), and so on until you process all the items with the same name. If you do not save the document, the items are not actually removed. However, the recommendation is that you avoid creating multiple items with the same name.
Subject: RE: Changing RTF fonts etc - duplicate fields problem
Rob
Thanks for that. Great isn’t it - Notes say you shouldn’t create multiple items with the same name and then what do they do - create multiple items with the same name !!
Paul
